S6 wrong way round
D
Deleted User
Guest
Hi all. My father has an s6 (not edge) and everything appears as though it is setup for a left handed person so the likes of the clock is top left instead of top right. This is the same for everything. How do we change it for him?
Thanks
Ok. When you look at your screen the likes of the clock will be in the top right. Settings for example...all the icons will be to the left of the screen followed by the text. His clock is top left. His settings menu is text then the icon on the right. Its as though everything is setup for a left handed user
Touch and hold a blank part of one of the screens, This should then see at the bottom of the screen :-
Wallpapers,Widgets, Themes and Screen Grid
Touch screen grid - 4 x 4, 4 x 5 and 5 x5.
And can that really affect everything being on the opposite side?
The setting is your choice, if it is 5 x 5 it might very well look lopsided. Try 4 x 5 and see if that changes.
Im getting him to send me a screenshot so i can show the issue
Heres a screenshot
Heres how mine looks
Then it is not down to the screen grid configuration. This is a puzzler.
Perhaps others may throw a light on it now that we have a screenshot is available
I have looked through all the settings and cannot find a resolution
