Safe mode loop
Saddkid
So... My 'waterproof' phone protector leaked at the beach and I obviously put my phone in rice and I luckily saved it. its working and connecting calls but it's been stuck in a safe mode loop for hours now and I can't seem to find something that works. Ive been all over the internet and have tried Litteraly everything.
Please help!!
Welcome to Android Forums @Saddkid :)
I'm also uncertain what your mean by "Safe mode loop". Its a term used in reference to PS4
If a PlayStation 4 system is only able to boot into Safe Mode (creating a 'Safe Mode loop'), this is a sign that an error is preventing safe start up and so I'm assuming you're LG Aristo 3 is stuck in safe mode.
"To get out of Safe Mode, please try the following.
1. Touch and Hold the "Power" key.
2. Tap "Power Off".
3. Once the phone is off, Touch and Hold the "Power" key again to restart.
The phone should now be out of "Safe Mode".
If the "Safe Mode" is still running after you restart your phone, I would then check to make sure your "Volume Down" button is not stuck. Check to see if it has anything stuck in it as well, dust, etc. Anything like this can cause the phone to go into, and get stuck in, "Safe Mode".
If that doesn't work try this...
Use the "Status Bar" to turn off "Safe Mode'. Pull down (swipe) the "Status Bar" of your phone. Now tap the "Safe Mode" button. This should turn "Safe Mode" off. Now your phone will automatically restart, so that it boots up out of "Safe Mode".
And lastly...
If you want to get rid of/disable "Safe Mode".
1. First turn off the phone.
2. Next press and hold "Power" until you see the manufacturers logo on the screen, then release the power button.
3. "Quickly" press "Volume Down" and hold it for few seconds until you see the message "Safe Mode: OFF" or something similar.
4. If you wanted re-enable it, simply repeat the steps above, and you should see "Safe mode: ON" rather than off."
If you have no choice but to factory reset your device be aware of Google FRP lock or youll be locked out of your device permanently.
https://www.google.com/amp/s/www.technipages.com/help-my-android-is-stuck-in-safe-mode/amp
