ratman7777
safe to charge zmax pro with smart charger 3.0? and will it make a difference?
I just received my Aukey. MAYBE even 75-80 minutes... this a guess though.I think with the one that came with phone takes2 hours. if I can get it down to 90 minutes id be happy
Yep, especially from USPS.got mine around 10 am gota love sunday delivery
Did you try this from 0 to 100?The original ZMAX PRO adapter charges the phone at 1% per MINUTE. That means it takes 100 MINUTES (1 hour and 40 minutes) to charge from 0% to 100%.
I'm not challenging you, BTW.
You know why I asked?Yes, I did. The charge from the original charger charges at about 1% per minute. A full charge from 0% to 100% (without using the phone while charging) confirmed it. It took 1 hour and 40 minutes. Also, you can plug the phone in at any time and test it for yourself, it's always 1% per minute on the original charger. So, anyone testing other chargers should use THAT as their guide to see if a different charger is getting better results.
I was able to check during a break:only at 80 percent after 100 minutes on new 3.0 charger
about plugging in spurts during the day / completely overnight.
