computergeek24
I have been looking for a list of apps that are safe to freeze other than the obvious verizon apps. Everyone's input is valued.
Another commando convert here also. I have seen a list from time to time, but have lost track so guess I'm no help at all.
What I've done tho is thru trial and error found a lot of stuff that freezes with no Ill effects. Some things I would have to thaw after it messed something up but only a couple. If you use titanium and just run down the list of stuff it is mostly obvious with a little common sense thrown in and remembering you can always go back for the thaw. I did not do to many questionable ones at once so I wouldn't have to remember what I had done, made it easier to just do a couple at a time if there is any question about it. And remember what one person might freeze another might not as they use it. So each list is kind of arbitrary in my opinion as everyone's needs and uses are different. I'd just explore and have fun with it, remembering what you've done.
The voice of experience perhaps? Yah, a little common sense is of course a good thing when freezing stuff.All true...except...NEVER NEVER EVER Freeze "Dialer" - even if you are using another dialer. It causes a Force Close loop that is very difficult to work around.
I have just rooted my Bionic and would like to know the benefit of freezing the garbage apps that Verizon included. Will freezing give me better performance? Will freezing increase battery life? What other benfits?
Thanks
