jaykesrwani
Greetings everyone ,
im using my sony xperia S , rooted , unlocked boot loader , running cm 10 .
wanting to change pixel density to about 160-180 ( native is 320 ) . because at such low ppi ( pixel per inch ) you can get tablet UI . which very cool and useful if you use HDMI such as i do .
i used first an app from the market to change the ppi .. that didn't work .
then i managed to edit build prop from an app called buildprop editor . that worked . when i rebooted i got the tablet UI as expected ( but launcher kept crashing )
then i wanted to to go back to native ppi . i restored the settings and rebooted and there's the problem BOOT LOOP . i had to reflash kernel and OS . for the phone to work again .
BUT i've seen people do it without problem on a nexus 7 for example .
Thanks a lot
So is there a way to do it safely ?
Thanks a lot
