Davy49
Hello All,
I use a Viewsonic gTablet, I already know that the android os is sure different than the ms windows os system I'm used to. With windows..when you plug in a usb 2.0 thumb drive, windows automatically recognizes it, and when you are finished using it, you just 'eject' it and then you can safely remove it. Is there ANY way to do this when using a android tablet ?
Thanks,
David
Thanks,
David
