Help Samsing Galaxy Note 2 s pen writing
scanman
I seem to recall a internet conversation somewhere talking about the fact that the hand writing to text feature is not working on the Sprint SGN2? I can't seem to get it working so this must be the case? If not, can someone tell me how to get the hand writing to text option working? Thanks
Mine works just fine. You can do it on most apps (unless you are entering a Password)
There is even a setting where when the S-pen is detected it will automatically bring up the handwriting to text box. Its easiest to play around with in the S-note app( for me anyway).
open up a new S Note. Click on the T towards the top. If you dont see the T, click on the icon at the top left that looks like a paper and pencil.
Once you click on the T, the keyboard will pop up. press down and hold the icon left of the space bar. a option box will pop up. Click on the T with pencil in the option box, and start writing.
Hope this helps
Hope this helps
All I needed was a little push. Got it thanks!!!
Your welcome. good luck
Little tip. to put in a subject, click the pen(drawing mode) than press and hold on the subject box. the box will get highlighted than click the box again and a cursor will appear in the box.
Does anyone know if you can "handwrite" text messages and it will translate from cursive to regular text? Also for the S-Pen note taking, if you're taking a note can you alternate between both keyboard text and written text (but having both on the final note at the same time)?
Please let me know if any of you have time! I think these options would be really cool!
Hey guys, quick question if anyone has the answer.
I would like to write in landscape and have the writing pad on one side or the other not on the bottom but keep the paper in portrait.
Is this at all possible?
