Help Samsung 4 problems
L
Laurel
Guest
I I can't play scrabble on my Samsung 4 tablet. I also can't see videos posted on facebook. Any ideas of how to make these work?
Which "scrabble" app (Play Store link or developer name to make it unambiguous). And what are the symptoms: game does not install, crashes when you try to start it, or something else?
As this sounds device-specific I'm going to move the thread to the Tab 4 forum, where it's more likely to be seen by people with the same device.
Scrabble works fine for me. Got it from the Play Store. As for Facebook, I don't use the app. I use the mobile site through Chrome. No problems with playing video from fb that way. I dislike the app as that is a huge CPU and cache drain when allowed to run in the background.
Decided to load the facebook app, thanks to Link2SD. No problems with video. I set it so that videos don't start up unless I hit the link directly. Not so much a CPU issue this time for me, thanks to root and Link2SD, but it still drains battery a bit more than usual if the app is allowed to auto sync. Using the built in battery saver helps a little.
