Help Samsung 4G LTE SGH T399 Rooting Help
Ethan42
Hello, I am looking for a way to root my Samsung 4G LTE SGH T399. I have tried various methods but they don't seem to work. I am pretty sure rooting it with Odin would do it but when I try to open the program a error message in Korean pops up so i cant do it that way. What I would like help with is if someone had a different way of rooting besides Odin or if someone knew a way to fix Odin so it will work on my computer. Thanks!!! Oh and if I wasn't clear on what happens to Odin here it is. It opens up for a split second then closes and that Korean error message pops up
Do you have the drivers installed for odin to work? Easiest way is to install Samsung Kies on your pc which will install them but make sure it's closed while you use Odin as they hate each other.
Sorry then. I'd try searching "xda Odin guide" and get the version from the link there..
Good luck
There is an app called Mobile Odin but unfortunately it requires root :(
Never have encountered that error. Must be something with that odin you downloaded. I've used the version from http://forum.xda-developers.com/showthread.php?t=2711451 . All I know is I've seen people mention to be cautious because some versions can have viruses.
Eh make sure that tmax and zlib dlls are in the same folder . That should fix that error. It was in the comments on that video and I just checked both are in the same folder as odin exe.
