UsCellSUCKS
The Samsung Acclaim by US Cellular with the Droid software is a BAD phone. If you are planning on purchasing this phone PLEASE DO NOT. US Cellular is standing by this phone and encouraging people to purchase it (possibly to get rid of the stockpile they have?) when they know that the phone does not work properly. If you call Us Cellular's technical support they will tell you that the problems with the phone are because of the Droid software and that as soon as the update comes out for 2.2 that all the problems will be fixed. It is not a droid problem, it is the phone.
THE BATTERY LIFE IS EXTREMELY SHORT! Talk on the phone more than 30 minutes and expect to have to carry your charger with you constantly. Play a game and it will drain your battery. Have nothing even running on your phone and walk through the mall for a couple hours and it will be dead.
PHONE FREEZES Talking on the phone to an important client....when "hello, hello" i was talking to myself for five minutes and I look at the phone and it is frozen. Press the buttons, nope, nothing. Call Us Cellular technical support (from another phone of course) and they tell you to take the battery out to restart the phone and wait the 45 minutes it takes to reboot and come back up to the phone so you can explain to your important client that even though you though Us Cellular was a reputable phone company you are loosing your faith in them to choose good phones.
BAD CUSTOMER SERVICE Call customer service with US Cellular and they will tell you that you made a bad choice in choosing to not exchange your phone for a new Samsung Acclaim, even though they can not make the new phone work any better than the old Samsung Acclaim, and you will loose the Apps you downloaded because they can't transfer those.
COUNTLESS PROBLEMS that Us Cellular was unable to resolve. Please don't buy a Samsung Acclaim phone from Us Cellular.
Believe in something better? What???? Believe that if you buy a US Cellular phone that when you call them to complain they will make up every excuse about why the phone is bad and
