Help Samsung Admire dropped in glass
gatricia
I recently dropped my admire in a glass of soda it didn't even go all the way in just the top I immediately placed it in a container of rice for 8 hours I took it out it powers up no problem but I can't do anything else when I go to slide to answer it won't do anything it's like it's frozen does anyone have any ideas what to do or is it that I"m totally screwed.
Hello gatricia. :)
Sounds like the soda might've caused some corrosion inside the phone, I'm really sorry about that happening, but you might have to send it in if you're still under warranty.
Open the phone and take rubbing alcohol and q tips and clean it well or with the phone off and battery out quickly dip it in rubbing alcohol and let dry fully before turning on. It sounds like u fryed the capacitive screen. If so u can usually replace them for 10-15 dollars
people should stop trying to multitask xD
never works out.
i think thats why they banned texting/phone use during driving. never works out.
this case is different because self harm was inflicted.
