W
Willner
Guest
Hi, my Sister has a Sasumg Admire and She told that install it a Custom Rom, I already Root it, but when I tried to put ir on Download Mode, IT DON'T LET ME!!! I already follow the steps to put on Download Mode: a. Turn the phone all the way off, then remove and replace the battery and make sure the usb cable is unplugged.
b. Plug the computer end of the cable into your computer.
c. Hold down the Camera button, tightly. The Camera button is kinda flimsy.
d. While still holding down the Camera button, plug the usb cable into your phone.
e. Wait a few seconds. You should be at a screen warning you about how custom roms are dangerous to your warranty. You already know that, so hit Volume Up.
But, when I replace the battery it turn on without I touch anything, so I can't get it on Download Mode. Is there other way to install the CWM Recovery? Thanks
PS: Sorry for my bad English
