D-U-R-X
turbo drinker
This is a work in progress and, as such, if you feel that there is anything that needs adding, please PM a guide or start a thread in Private Chat With Staff with your suggestions.
Many thanks
1. General Android phone FAQ's?
2. How can I improve my battery life?
3. Are there any Epic 4G Tips & Tricks?
4. What are the known problems with the Epic 4G?
5. Forum related questions.
6. What is root?/What does being rooted mean?
7. How can I fix/replace my screen?
Q: General Android phone FAQ's?
A: Here is a thread on general Android Phone FAQ's
Q: How can I improve my battery life?
A: First off, you should read this post: Fix for fast battery draining. The following post is also worth checking out: How much battery life do you get?
You do not have to follow all of the tips/suggestions, but the advice is sound and will help. Smartphones operate on a sort of spectrum. On one end you could put battery life, on the other end all those options like wifi/3g/sync (among other things). If you want great battery life you can't have those on all the time. If you want those on all the time, you won't get great battery life. It is best to find the compromise that works best for you and what you want most out of your phone.
Q: Are there any Epic 4G Tips & Tricks?
A: Epic 4G Tips & Tricks
What are some of the problems people have with their Epic 4G?
A: Epic 4G Support & Troubleshooting
Q: How can I fix/replace my screen?
A: This thread has step by step instructions: How to fix Samsung Epic 4G screen
Many thanks
