Help Samsung Epic Network connection problems??
Recently..In the past couple of weeks, the 3g connection...has been...half working and half not working
google and facebook seems to work fine
But i use this search engine thing (not google) and i search something.
The results show, but it says there is a problem with the network and cant display the actual page when i click on it
also, i have some apps that use internet connection
It worked fine before, but not, it takes a long time for the app to load to the main screen, then it says trying to connect to the network.. and it doesnt even say it cant connect. It just keeps saying trying to connect to the server..
I dont think it is a problem with the app cuz its the same for my other apps that use internet connection.
And when i turn on wifi, the app works fine.
Im not sure if this helps in any way but
i went to setting and phone into , then status,
and it says signal strength: -86dBm 0 asu
Idk if - means negative or that thing is just there or whatnot...
And it says mobile network state: disconnected.
Is this a problem with my phone or is this happening to other epic users?
Okay, i just checked again and i opened internet and it said cannot connect to internet. Then it just opened google right away. I tried facebook and it seems to be working normally.
How can i fix this??
Have you tired to update your PRL?
