Are you sure it works on a 64 bit ver. I check the Samsung site & I find the details very skimpy. All that they say is 'Win XP/Vista/Windows 7' nothing more. Only optio is to try again
1) Check if your antivirus blocks installing(this will be the most case).
2) Check the User Control settings and be sure that you've the proper rights to install device drivers.
3) It's safe to disconnect from Internet while installing drivers. Because these samsung's drivers and kies are all bunch of bugs. It's your luck to get everything done.
