J
jocelyn162
Guest
Hi. I have a samsung galaxy ace S5830, and I got a new battery four months ago. After recharging it last night (for only about 2hours), it said that it was fully charged so I unplugged it. The following morning, my cellphone tells me that it is very low on battery and asks me to recharge. However, I did not use it whatsoever during the night as it was off the whole time and I have no applications active throughout that time (I always kill all running applications after I'm done using them).
When I did recharge it, while on the charger, my phone repeatedly gives me the typical message that my battery is running low and that I should recharge it. It repeatedly shows this message whenever I simply picked up my cellphone while it was on charger.
My phone uses a Samsung 3.7v li-ion battery 1350maH.
Can anyone tell me what's wrong with my phone?
If this doesn't happen again, how do I best recharge my li-ion battery to prolong its battery health? (I already do everything I can to keep its battery runtime as long as possible by turning off 3G, Wifi, bluetooth, GPS, vibrate, and kept the screen brightness to darkest.
Does anyone have any li-ion battery recharging properly methods for me?
Thank you
Thank you
