Root Samsung Galaxy Ace GT-5839i - android is not working :(
SimonL
Hi all i currently have a Samsung Galaxy Ace GT-5839i on contract from three and I was messing around with my files and i deleted sum apps and that messt my phone up when i did a reset it loads up then the setupwizard crashs.
am unable to use my phone can not dial out or anything just a blank screen.
after that it will just goto logo screen and hang i think i would have to reinstall my firmware but i seen alot of demos on here on how to do it for other phones but not the 5839i what programs would i need to fully reinstall android ??
I tryied to reset my android to a other custom rom
http://androidforums.com/samsung-galaxy-ace/431900-go-cm7-back-offical-gingerbread-guide.html
but the odin dont pick up my USB cable it dont go yellow and always says connect phone any ideas???
thanks alot
thanks alot
Are you rooted??
Do not use Odin 4.38, its not for this phone. That version is for S5830, not your variant. Use the firmware and Odin and support files for your particular version only. If you use things made for other models, you may end up bricking your device.
what version would be for my phone i downloaded the Samsung-Updates.com-GT-S5839i_COS_1_20120712183918 ram but can not find a version of the app to install it also am unable to go into download mode on my phone i think its because my phone was set not to allow unknown apps before i crashed it i forgot to back up that kick me in the teeth i guess *lesson to be learned always backup* lol
ok i found out what problem is it seams my default theme files were courrpeted that is why i get error if i use a custom theme phone works, is there any links to the default Samsung Galaxy Ace themes that come with phone??
Are you rooted??
hi!on samung galaxy ace i have updated from 2.3.1 to ics through root but my phone is not showing
i had same problem but just my phone is not supported by that software i tried all versions it only works on 5830 phones :*( but i got my phone working now just using a custom theme till i work out how to install OEM theme agen
this problem of deleting files can be solved easily the thing that you need to do is to update your phone software. It sometimes may happens because of new versions of Android phones...
you can also take help of
Thank you Edna for giving your suggestions it is exactly right to update it...
or simon you can take the help of zonzoo and topdollarmobile which will solve your problem with android..
Hey! Recently I was on CWM on my phone and so I decided to to do a factory reset and also wipe my cache a battery stat for no reason.Now my phone starts but it just stops on glowing samsung screen. Please help me fix this. I have a rooted Galaxy Ace S5830
Cheers!
Cheers!
Flash a stock samsung firmware via Odin.
All needed files and guides are available on sammobile.com
