Help Samsung Galaxy Ace Wallpaper Problem
Everytime time I turn off my phone I lose my wallpaper, it's still save to the phone but it always resets. It's driving me mad, I took it back to the store yesterday and it looked like they fixed it but I decided to test it again and voila no wallpaper
THIS IS THE EXACT PROBLEM I AM FACING!!!! plz post if u find the solution....:mad::mad:
i doont know if this will help at all but have you tried using a live wallpaper restarting...if the live w' stay the same then change to the wallpaper you want to use and see if it fixes the prob,
are you using the stock launcher?
I worked out the problem it's where the apps are getting saved to. What you do is you go to your settings/applications/manage applications open an app and "move to phone"
oh thnx... i will try it
@ chismay - thnx but i think the prob will be solved by moving the live wallpaper to phone memory....
