Help Samsung galaxy blues
samfox1
Hi there. Can anyone help me witha wee problem with my brand new Samsung Galaxy Ace. can u tell me how I move music files from the phone memory onto the sd card? Can't find any way to do it on the phone. Thanx
Welcome! There's a Samsung Galaxy Ace section. That would be the place to go to ask questions about your particular phone.
If the Ace is like other Android phones, you'll probably need to download a file manager app to move files on your phone, from the phone. Alternatively you could connect the phone to a computer with a USB cable, and use the computer's file manager to move the files "the long way".
Good luck!
All your music files are in the sd card only, you cannot store them on the internal memory, as it is this phone has a very less internal memory, if you somehow store files there then there would be no space left for apps or any data/cache.
