Is there a way to separate the volume control for the notification ring and the call ring? Right now, as I see it, they are the same. I would like to make them different volumes. Maybe there is a widget.
You should be able to adjust notification and media as well as call volume separately.
When you press your volume button, does a slider pop-up with a settings icon beside it?
If so then press that icon and you can adjust all 3.
Well actually, the widget doesn't work! When I adjust the notifications, the ringer adjusts to the same level. Darn! While I like the ringer loud, the notification sound whenever I receive an email is annoying! They seem to be programmed as one.
