Help Samsung Galaxy Help
pixagirl
Hey Guys,
Just got a new samsung galaxy and my friend has texxt me a picture. I want it as my wallpaper. I can view the picture and it gives me the option to save it but I cant find it anywhere once it has been saved. Can you please tell me how to save it correctly and then use it as my wallpaper???
Much help would be appreciated
Once you saved the picture, open the Gallery, and the picture should show up under a folder called download. Open the picture, select it, and click on More, Select Set As, and then select Wallpaper.
You can also find it in the download folder on the internal SD.
