Help samsung galaxy mini storage
Hi, i am using galaxy mini, total phone internal memory is 181 mb out of which 150 mb is occupied. my phone has external memory of 8 GB (25% is utilized up to date).
Problem i am having is related to storage setting, i.e, i want that the new apps i download in future must utilise SD card and not phone memory. Recently i tried to download a game of ~50 mb from android market, but my download did not occur and give the error that "enough memory is not available, plz remove the current applications to download this app." i figure out that app i tried to download tried to utilize internal phone memory. i even bought a 8 GB aditional memory card to download more stuff...
Let me explain "my research" i did to solve the issue:
1. i search in "setting" and i found no option in it to set SD card as primary storage devise.
2. i go to settings > application > manage applications > running > setting storage (v 2.2.1). All the options (i.e. force stop, uninstall, clear data, move to SD card) is "off". ( i am getting impression that the function is disable??)
if someone using the same phone reading my question then kindly explain me this and help me out, i am feeling that i cannot install any apps as my internal memory is nearly full??
Hi there is a method available in which you partition your sd card into 2 ie 1gb and 7 gb then set 1gb partition as EXT format and upload a script to your phone which will make your phone see the EXT partition as your primary storage.
The full details are on XDA just search for the hack gl
hmm..i dont really knw how to do tat..can u show me step by step on how to do tat??u meant tat i need to do tis on my phone or on d pc first??
Hi you can use Android SDK tool kit which you can download from internet. You have to install it. Now follow these steps:
1.Connect your phone to PC.
2. Open up command prompt and type cd c:\program files\android\android-sdk-windows\platform-tools (or the location of the folder if you installed somewhere else).
3. type adb devices. It will open a port probably 5037 and will list a device.
(if you dont see any device with its number then drivers for your device has not been installed on your PC. To do this you need Samsung Kies to be installed on your PC).
4. Once device is listed, type adb shell and it will go down to next line. type pm setInstallLocation 2 (Type exactly same letters with small and big letters)
Thats it, now every app you install will go directly to sdcard, if you need to move existing apps to sdcard that can only be done if your device is rooted and you have proper app to move apps e.g App2SD or Link2SD.)
HI there
I have just bought a 32gb sdhc card for my Galaxy Mini. The problem is that I can not see the music files I put onto it. There were no issues with the original 2gb card. The files are definitely MP3 as well.
The memory usage has gone down which is a good sign.
Any ideas please?
Thankyou
