Help samsung galaxy note 2
Hello and welcome to the forums, redbug11.
In the Call Settings menu (when you have touched the stock "phone" icon and the keyboard opens up, hit the device's main menu soft key) select TTY mode and you'll be presented with several TTY modes to choose from ("Full," "HCO" and "VCO"). :)
thanks for the welcome Frisco,still doing same think wrong,from the home screen i press the phone, which bring up the key pad, i then press the bottom left hand menu key and a menu come up with 4 options one of them call setting, press that one, up come a menu with a long list of setting,starting with call rejection and so on,I've check all the menu in this lot by no mention of the tty setting.regard redbug
Hi
I'm with the OP, there is no TTY mode option in the menu on the International N7100. Perhaps Verizon has a different menu. (Why would you want to type letters anyway? The pause, + voicemail and silence work by long pressing)
Roger
H'i i'm with t-mobile uk and i need to put in a code that they sent to update, and it contains letters,star,numbers , then press the call key. thanks redbug
H'I i've tryed 4 different dial on play store, none let you use the letters on the dialer. thanks for the help redbug
Hi
Put your code in the clipboard
Paste it into the phone number field of a new contact and then call the contact!
