Help Samsung Galaxy note 4 question
Qulian
Hi so i just bought a Samsung Galaxy Note 4 SM-N910A / SM-N910T, when i purchased it i really didnt know much about how the region locking worked and have only just found out its a US phone. I thought when it said unlocked it meant i could use it with any carrier. Im in the UK and i was wondering if the phone will work in the UK or if i should return the phone? Thanks for any help
I suspect that it will indeed work as it is a world class phone, and the 4g part of it will cover most of the band plans. but as it is a carrier supported phone, some of the band plans may be omitted.
I will refer you to http://willmyphonework.net/
as they are the leading authority on such things.
