repairsuniverse
Need to tear down your Samsung Galaxy Note 8.0 N5110 to repair a broken or cracked touch screen or even faulty LCD display? This guide brought to you by Repairs Universe will assist you in installing the following parts:
Recommended tools to perform this repair:
Galaxy Note 8.0 N5110 Repair Guide:
See figure below connector and screw locations.
Now we can start working at the top of the device.
See figure below for connection and screw locations.
Now that this has been completed you can start from the lower half of the device.
Now that the screws, connections, and speakers are released you can now begin removing the motherboard and other components.
See figure below for reference.
Next you will want to remove the vibration motor and memory card reader assembly.
Notice: This Samsung Galaxy Note 8.0 tear down guide is for informational and learning purposes only. Perform this repair at your own risk.
- Samsung Galaxy Note 8.0 Touch Screen Digitizer
- Samsung Galaxy Note 8.0 LCD Screen
- Other internal components
- Plastic Pry Tool(s)
- Small Phillips Screwdriver (#00)
- Adhesive Strips (required for installing new screen replacements)
- Heat Gun or Blow Dryer (required to heat up and loosen adhesive)
- Before you begin you must power off your device and remove the stylus pen.
- Next take your pry tool and insert it between the seam of the back cover and the housing. Evenly pry along all sides and corners of the back cover to release the clips securing it in the housing.
- Once the back cover has been removed take your Small Phillips Screwdriver (#00) and remove (8) screws that are circled in the figure below.
- Now gently pry up the battery and release the connection highlighted below to remove it from your device completly.
- Take your Small Phillips Screwdriver and remove these (3) screws circled in the figure below.
- Then, Taking your plastic pry tool you will need to release the (5) pop connections on the motherboard.
- Using your Small Phillips Screwdriver remove the (7) screws circled in the figure below.
[*Next take your plastic pry tool and gently release the (6) connections shown below. - Note: The connection highlighted in yellow has a metal plate covering the connector. You will need to pry and lift up this metal plate to expose the connection in order to release it.
- Finally take your pry tool and gently lift up and remove the (2) loud speakers located on the left and right sections at bottom of the device.
- Use your plastic pry tool to gently pry up the bottom of the motherboard to allow you to remove it from the housing. (Use extreme care when handling the motherboard.)
- Now take your plastic pry tool and gently lift and remove the headphone jack assembly and front camera.
- Next you will need to remove the microphone and button assembly. Carefully pry up the flex ribbon starting at the top and slowly peel down towards the bottom. This flex ribbon is held on by a little adhesive so you will want to be careful not to tear this ribbon cable.
- Taking your plastic pry tool and first pry up the memory card reader. Be careful as the card reader and vibrate motor are attached by a small flex ribbon cable.
- Next you will need to pry up the vibrate motor from the housing (it is held down with strong adhesive.)
- You might find to remove the vibration motor that using a small flat head screwdriver or other metal pry tool will give you extra prying leverage to release it from the adhesive holding it in place.
- Next you have to remove one final flex cable by taking your pry tool and releasing it from the jaw connector located underneath the ribbon.
- Next you are able to flip over the screen assembly and housing and apply heat to loosen up any adhesive.
- Use your heat source on a medium setting, roughly 3-4 inches away from the screen.
- Be sure to apply heat to all edges of the screen to loosen up the adhesive holding the screen in place.
