Samsung Galaxy S 4G Tips and Tricks
How to download and install free applications
To download and install free applications, perform the following steps:
  • Step 1. At any Home screen, tap Applications.
  • Step 2. Tap Market.
  • Step 3. If prompted, add or sign in to a Google™ Account.
  • Step 4. If prompted, review the Android Market Terms of Service.
  • Step 5. Tap Accept.
  • Step 6. Tap Apps.
  • Step 7. Tap All applications, or scroll to and tap the desired application category.
  • Step 8. Tap Top free.
  • Step 9. Locate and tap the desired application.
  • Step 10. Tap Install.
  • Step 11. If prompted, tap OK to acknowledge application access.
NOTE: The application downloads and installs. An alert appears on your phone when download and installation are complete.
http://sgalaxys.com/archives/category/samsung-galaxy-s-4g
How to use Voice Commands through Phone
Samsung Galaxy S 4G Voice Dialer
To use voice-activated dialing through Phone, perform the following steps:
  • Step 1: 1. At any Home screen, tap Phone.
  • Step 2. Tap the Voice Dialer icon
  • Step 3. Say a command when the Voice Dialer flashes the Listening prompt.
    NOTE: As an example: Say, Call John Smith.
  • Step 4. Confirm your selection.
    NOTE: If you said a name that has more than one match in contacts, or if you stored more than one number for the contact, the phone will prompt you to make the appropriate selection.
How to turn DriveSmart on or off
Samsung Galaxy S 4G DriveSmart
Turning on
To turn DriveSmart on, perform the following steps:
  • Step 2. Tap DriveSmart.
  • Step 3. Tap DriveSmart again.
  • Step 4. Tap OK.
Turning off
To turn DriveSmart off, perform the following steps:
How to access Inception
To access Inception, perform the following steps:
  • Step 2. Scroll to and tap Inception.
  • Step 3. Log in to Media Hub.
  • Step 4. Tap Inception.
  • Step 5. Select one of the following options:
    • doubleTwist
    • Video Player
How to access DriveSmart
To access DriveSmart, perform the following steps:
  • Step 4. Tap OK.
NOTE: A notification icon will appear in the status bar when DriveSmart is running.
How to uninstall or delete applications
Samsung Galaxy S 4G app uninstall
To uninstall or delete applications, perform the following steps:
  • Step 1. At any Home screen, tap the Menu key.
  • Step 2. Tap Settings.
  • Step 3. Tap Applications.
  • Step 4. Tap Manage applications.
  • Step 5. Locate and tap the application you wish to delete or uninstall.
  • Step 6. Tap Uninstall.
  • Step 7. Tap OK.
  • Step 8. Tap OK again to confirm.
How to download and install paid applications
To download and install paid applications, perform the following steps:
  • Step 3. If prompted, add or sign in to a Google Account.
  • Step 6. Tap Apps.
  • Step 8. Tap Top Paid.
  • Step 10. Tap Buy.
  • Step 12. Tap Select payment method.
  • Step 13. Tap Buy now.
i keep trying to send a picture message but the person i send it to never gets it. it says "sent" in the message but it is never actually received. how do i fix this?
Reboot your phone. Worked for me today. :mad:
I'm just hoping there's a fix in the works coming out real soon....
This is all new to me (I've been using an iPhone on TMobile for a few years) and isn't intuitive for me. Knowing how to download apps was really, really helpful. THANKS<
I used Samsung s4 LTE 4g bought from Singapore to be used in Sri Lanka network 1800MHz band 3 how could I activate to band 3 from band 5 ( Means activate the phone to work on 1800Mhz band 3)
When typing in my S2 or Nexus tablet, the autocorrect feature automatically enters the correct spelling when I touch the the space bar or enter a period. My S4 won't correct misspellings unless I choose one of the corrected options. Anyone know how to get the S4 to correct like earlier modrks.?
