Hello,
I 've just got an SD Card of 16GB. I thought that it would be better if i moved some apps to the external memory so as my phone response quicker than before.
Since i moved some apps i 've experienced some issues.
First, i ve organize my apps in the tabs in same way, after moving them in the external memory and rebooting my phone these apps are not in the way i put them and also two of shortcuts i had made disappeared.
Secondly, i have the Android Assistant application which gives me the ability to boost my phone by deleting some useless data. After moving apps to the external and boosting my phone several times it shows me that it cleans a big amount of data which this didn't happen before.
And last, even if i moved these apps the size of internal memory didnt change! Why is that?
If someone could help me please, before i break down my phone with my ignorance.
Ps :what are the pros and cons of moving apps to external memory
