Help Samsung Galaxy S rooting in non tech terms
NZ_Nitro
Member
well did mine last night, finally!!!! there are many pitfalls when following instructions out there, I have done it so if you are having any issues ie 3 button reset I have the answers for you in non Geek he he, its easy to fix the 3 button reset thing and easy to flash, if you have ALL THE INFO
the green section I never needed to bother with however there is one little snipet that holds the key which is the Java JDK link, download JDK for your operating system and install, if you dont do this it caused the adb method to not work, now using the instructions on this page it really does fix the button issues
Hey all. Noob here. Just got my Vibrant rooted. Trying to download ROMS via ROM manager but it keeps asking me for a modem. What does this mean?
