Help Samsung galaxy S
Hey I'm new to this so please hell me out and be patient. Well I recently purchased the Samsung galaxy S and I absolutely love it. The only thing I can not seem to figure out is how to turn off my 3G because it is draining my battering and my bill is high. I even went as far as to download a WiFi app but it doesn't turn off. Please help!!!:confused:
If you are running 2.1 (eclair)you need to download an app like Quick settings and turn it off through that or you could create a false apn in the settings and then select it.
If you are running 2.2 or 2.2.1(froyo) just long press the power button until you get a pop up window and then select data network mode to turn it off.
You can check what OS you have by going to menu->settings->about phone->build number.
You can turn off 3G very easily.
At the top the screen the bar with the signal strength/battery symbol drags down and you can use the data button to turn 3G on and off.
