You'd need to browse to the location of the ringtone using a file explorer on the phone (Astro/ES File Explorer) or connecting to your PC in mass storage/Disk Drive mode and delete it from the folder it's stored in. For it to appear in the list, it needs to be in a folder called Ringtones, so it should be relatively easy to find.
On the Galaxy S2, you dont need to download Astro. The My Files app is already built in.
No probs
1. Download & Install Astro File Manager from the market
2. Open hit
3. Hit the Search Button on your handset
4. In the Page that appears, type the name of the ringtone you want to delete, press the magnifying glass on screen.
5. The file should appear on the screen, long press it and select open folder/directory, select that
6. Long press the file again in the new window and press delete.
All make sense? If not, just follow the instructions and tell me where you get stuck.
Where is it located ????
App drawer. Just go in there and look for the icon that looks like a brown folder and says My Files.
as for the Zedge, you did not mention where you got the ringtone so we assumed that it was a random mp3 you put somewhere in the phone.
So I had a similar problem to yours. I created my ringtones a little differently so not sure if this will work for you (and maybe you already figured it out since it has been a while since you posted) but I thought I would put this up for you anyway or any future readers.I'm having a similar issue. I edited some mp3 files in garageband and used Kies Air to put them on my phone. I used the media>audio>ringtones folder to place the file, however when I inserted a better version of the song with the same name (e.g. "The Show") the older song still appears in the ringtone list screen even though I deleted it from the folder and there is no trace of it.
I also tried completely deleting the ringtones folder to eliminate any possible sign of the file, and now the names are still there but they won't play anything because there is no file to play. The names showing up is really aggravating me
I used no additional apps to help make the ringtones, only my laptop. Can I ever delete the 2nd obsolete file without having to reset my phone to defaults?
How do you delete a ringtone you down loaded and no longer want underr your ringtones ?
Thanks
