Hey guys, I got this extended battery a couple of days ago and it works so well that I thought I would share it with everyone.
Normally I would get 4 hours or so out of the OEM 1800mAh battery that came with the phone under heavy use. I would be lucky to get 14 hours without using it at all. I got the QCell 4100mAh extended battery from amazon and after charging it for 9 hours like it says to do, it lasted well over a day. I even got it to fit in my otterbox defender case by keeping the front plastic piece on and just popping it into the rubber outter case. So far I love the battery power and I am sure you all will too.
The Battery:
Amazon.com: QCell Sprint Samsung Galaxy S2 Epic 4G Touch D710 X-Life 4100mAh Extended Battery + FREE Battery Cover! (NOT Compatible with i9100/T989/i777): Cell Phones & Accessories
Battery Usage With OEM Battery:
Battery Usage With QCell Extended Battery:
Both pictures were taken with the battery close to dead. I tried to use both the same amount in terms of internet and maps and music.
I hope you guys enjoyed my first post.
Press thanks if it helped! =]
The Battery:
