Powering off on it's own is not right. It could be due to a number of different factors. You might try powering off your phone, removing the battery, wait a minute and reinstall the battery and reboot. This will sometime clear a silly problem phones develop. If that does not fix your problem.. the problem is more serious. You could have a software problem... think back to when the problem started and see if you might have installed something new at that time. Sometimes a poor install will cause a power down situation. It could be a glitch in the OS. Sometimes an update or a major change to an operating system will cause a reboot or power off. A factory reset is the answer if that's the case.
You will have to play with the phone and perhaps isolate what is the most likely culprit. You can then seek more help or perhaps fix the problem with the information above.
Best of luck to you...
