Help Samsung Galaxy S6 Edge G9250 & G9200 Android 5.1.1 Firmware
Manoj210891
Android 5.1.1 Firmware is now available for Samsung Galaxy S6 Edge SM-G9250 & SM-G9200.The users can also update their device to this new firmware through Samsung Kies or OTA (Over the Air). It is always recommended to update your device with the latest firmware to fixes bugs in previous version.
Pre Requisites:
Before proceeding to update guide, we recommend to backup all your device data and settings to restore later when you need that. However, official firmware restore all previous data but if your device get stuck at bootloop issue or fall into any error, the backup file will help you to restore all your data.
  1. Check your device battery percentage, make sure that your device have at least 60% battery power
  2. Backup all your device data and settings to external storage
  3. Check that USB Debugging is Enabled on your device, otherwise it is not possible to connect and transfer files between PC and Galaxy S6 Edge SM-G9250 via USB
  4. Install USB Driver for Galaxy S6 Edge SM-G9250 on your PC
Hong Kong Version Download Link
NOTE:-Disable AdBlock. If Adblock Enable Link not work.
