merciadriluca
Member
Hello. I've got an up-to-date Samsung Galaxy Tab 2, for which I've also got an external keyboard. This keyboard is a Samsung one. For some characters, I've got issues. For example the "@" is impossible to write. I therefore downloaded the program "External Keyboard Helper". I however need to launch it every time I plug the keyboard. It gives me a list of two choices concerning the typing mode: "Samsung keyboard" or "External Keyboard Helper". I then need to choose "External Keyboard Helper", for which the choice of the "belgian" layout gives me the correct layout, with "@" and so on. The issue is twofold:
1) In the "parameters" menu, my "Samsung keyboard" checkbox is grey and cannot be unchecked. The "External Keyboard Helper" checkbox is checked too. How can I manage to make the aforementioned choice of "External Keyboard Helper" automatic when I plug the keyboard?
2) Moreover, when I check "External Keyboard Helper" in the "External Keyboard Helper" menu, unplugging the keyboard results in no virtual keyboard. I wish the virtual keyboard would reappear.
Note that the configuration is the following:
* External Keyboard Helper is configured to have a Belgian layout;
* Samsung Keyboard is configured to have French(CA) or French(FR) layout.
Thanks for any help.
All the best,
All the best,
