vishal goyal
Hello,
I want to factory reset or hard reset my samsung galaxy tab 2. But each time i reset it shows that data is deleted but again restarts with same account and application as if its a normal reboot.
Also, i am not able to uninstall applications from it. It shows that apllications are uninstalled but then it again gets rebooted automatically and all the apps are there in its place.
Please help.
Please help.
Before taking it to the shop I would try the emergency firmware recovery using KIES in case that resolves the problem
