Samsung Galaxy Tablet 1 Wifi issue
xDavid
I cannot connect to my WiFi on my tablet anymore it used to work but for a few days now it just stopped working, other internet connections work but not my home internet connection. Now every time i try to connect to my home internet connection this is what it tells me... scanning..... obtaining IP address from.... disabled secured with WEP.... i even tried putting in the CORRECT password in 30 times i even made sure it was the correct password by using my phone with the same password and it works on that..... (the internet stopped working when it was on the right password) I tried many different things like reseting my tablet 30 times!!!!! 30 freaking times :( with different methods still cant get my home network to work, Reset the router/modem still nothing, and used static ip address still did not work i tried every method on my device. PLEASE DO NOT TELL ME TO FACTORY RESET MY SAMSUNG GALEXY TABLET 1.
1) Change the router from WEP to WPA2/TKIP (ot WPA2/Personal). WEP is so easy to break (there are apps to do it) that any 6th grader can get into your network.
2) "Forget" the connection. Then connect again and put in the password (and remember, case counts).
