trancytony
2 days ago, I've decided to reset my phone by doing the factory data reset so that I can remove the Super User app on my phone and I did forgot that you cannot remove that app unless you unroot your phone, so I made a mistake and then wala, all my files apps are deleted and it felt like the phone was brand new for it's done undergoing it's factory data reset. I've decided to connect to my wifi hotspot here in my home but the problem is once i enter my password and press connect, it's stuck on Obtaining IP Address, decided to do a factory data reset again and then it did nothing to the wifi problem, it still exists,
did try to do some static ip method by putting some ip address, gateway, netmask, dns, I finally got connected to the wifi hotspot, YAY!
, but the problem is, I'm connected but there seems to be no internet access on my phone, so it didn't worked at all, so I removed the ip addys, gateway, and others and disabled Use static IP, so here I am back to this Stuck on Obtaining IP Address problem. that's one, I can't connect to the internet
the second is that when I tried to check my status, there seems to be no IMEI present around, it's Unknown, then I checked the advanced of wifi settings and the IP address is unavailable that leads to a problem of 3
So, guys, i need your help how can I fix all of these?
, whoever answers gets a 0.00001% chance of winning a cookie LOL,
, thank you in advance
, but the problem is, I'm connected but there seems to be no internet access on my phone, so it didn't worked at all, so I removed the ip addys, gateway, and others and disabled Use static IP, so here I am back to this Stuck on Obtaining IP Address problem. that's one, I can't connect to the internetthe second is that when I tried to check my status, there seems to be no IMEI present around, it's Unknown, then I checked the advanced of wifi settings and the IP address is unavailable that leads to a problem of 3
