can any one help me plzzz why is it my galaxy y battery always battery low i 12 hours standby mode need to charge it again. i just it for 1 month i don't know if its the battery or the apps killing my battery i already installed adriod booster task killer
go to settings and go to the wifi and mobile networks>> open the mobile network and uncheck the use packet data, also go to contacts and open account>>> uncheck the background data...
also you can lower the brightness of the phone.. it really saves the battery..
THis really increases the battery life of my samsung galaxy Y...
Download the 3g data toggle widget and turn it off when not needed, my y can then go all day without losing battery. Look on google for android battery saving tips.
And uncheck background data, but it needs to be on for the market.
i have the same problem..i fully charge my batt one night and when i woke up..lowbatt again..its anoying.. i will dl juice defender and hope it will work for me
it's normal because the device is a smart phone.
taskilling apps are not a good idea. they won't do much..
you can increase you device's battery life by.
*. deactivate packet data(on mobile networks settings screen) when you don't use the internet.
*. lower the brightness of the screen.
*. when you are not downloading, always use 2g networks.
with these setting your device will run up to 1-2 days.
