samsung galaxy y pro duos problems..
arnabcool
hi ,i am using this handset for 3weeks and found this 2 issuses.could nt solved so need ur advice....
first of all as this is a dual sim ph when i send text messages it always sends ffrom sim 1 instead of sim 2...it doesnt shows sny options from which sim i want to send it...i am using go sms pro....
second oe is when i am listening to a song on head phone snd the screen gets locked the song stops...any solution for this im feeling frustrated now...!!!:mad:
similarly i am using 3g in sim 1 but i found it is also using sim 2 2g network..i.e both the sim r using internet @ a same time like a parallel connection..
help me out guys i am loosing money daily for all this craps..:confused::confused:
For 1 issue just drop down main screen you will found out two option means sim 1 and sim2 just select sim which one you want use now and start sending message.
For 2nd :- Yes, Go to setting option change screen lock timing.
For 3rd:- Go to setting >network>mobile networks> chose sim which one you want to access net that's easy .!!:)
