Help Samsung GT-I9502 hangs after rooting.
I need help Please! I rooted my Samsung GT-I9502 Dual SIM using ODIN 3.04, flashed CMW root and CSC root. Rebooted it and it hangs with the SAMSUNG logo on the screen.
This is what appears on my screen for hours.
Well at least you still have CWM so just download a suitable rom to your pc, copy it to the root of your sd card so it's easy to find, put it in your phone, boot into CWM, do a full wipe, install the rom, reboot :thumbsupdroid:
All I can suggest is search XDA Developers site (it's a ****in nightmare to navigate, I hate it) so you'd be better Google searching "custom rom "my device".
Also Google what the code name for your phone is, for example a nexus 6 is called "shamu" my phone is called "bacon". That will make it much easier to search for a rom.
Trouble is your phone doesn't seem very popular so you could have trouble finding a rom so if you can't, come back and we'll try n find you a stock factory rom k.
Good luck and hope I made some sense
For a stock factory rom search sammobile.com/firmware. They have to be flashed using Odin and you'll lose root and CWM
