So here is the scoop – been through Google support, Sprint support, and can’t fix the problem. All sync functions work fine, except when I enter a and information onto my Google calendar via the phone – the info will not show up on my Google calendar on the computer. Sprint seems to be aware of the problem but had no idea how to fix. Any ideas? Thanks!
When you create a calendar event on your Intercept, the second section says Calendar and underneath that it says My Calendar. That is the default Calendar. Tap that section and you will see all your calendars listed. You must change the green dot to your Google Calendar. Dumb, I know, huh? But it's the only way to sync what you create on your phone to your google online calendar.
