S serenabeans Lurker Aug 1, 2011 #1 Does anyone know why my samsung intercept doesnt have the usb icon pop up in my notifications?
lunatic59 Moderati ergo sum Moderator Aug 1, 2011 #2 You may be set to connect automatically in kies mode, or more likely yu have a bad cable. Samsung phones are very particular about the usb cables. To check Kies mode go to menu>settings>applications>usb settings
lunatic59 Moderati ergo sum Moderator Aug 1, 2011 #4 serenabeans said: i dont have a usb setting? Click to expand... It's there somewhere, unfortunately Samsung has decided to mix up the menus. If you ask in Samsung Intercept (Sprint) - Android Forums or Samsung Intercept (Virgin Mobile) - Android Forums they'll be able to tell you where it is.
