Help Samsung keyboard doesn't Swiftkey Flow anymore
nsa_sailor
The Samsung keyboard just quit swiftkeying. Was working previously, but now when I try it doesn't work anymore. When I go into the settings, the checkbox for Swiftkey Flow is checked but greyed out, I can't uncheck it anymore. I tried the Reset settings and that didn't do anything.
Any ideas?
It's part of the keyboard so you can't turn it off, if you don't want it on them don't slide your fingers across the screen. If you do want it and it's just not working then I'm not sure why that's happening. Try plugging it into kies or something and see if that fixes it.
The Samsung keyboard just quit swiftkeying. Was working previously, but now when I try it doesn't work anymore. When I go into the settings, the checkbox for Swiftkey Flow is checked but greyed out, I can't uncheck it anymore. I tried the Reset settings and that didn't do anythin.
If you have any services in accessibility turned on the swiftflow feature stops working for whatever reason. :banghead:
Mine still has swiping capabilities. Not sure if this is what you're talking about.
-Sent using the force
