Samsung keyboard problems
Hey guys
I have a problem in my galaxy ace android 2.3.7
My phone doesn't have Samsung keyboard,it has another keyboard but I want that Samsung original keyboard.How can I get and install that on my cellphone? Plz help me:confused:
He has android 2.3.7, that is a custom rom, probably cyanogenmod i think.
armansmead, you need to get the apk file for the samsung keyboard that can be run in your rom, and then push it into the system.
If its cyanogenmod, I don't think pushing a stock keyboard app will work. You will need a ported one (if there is).
I suggest you stick with this keyboard or return to stock (or stock based) ROMs.
CM cannot run stock apps, its framework won't support it, but there might be a ported app around or another similar to the stock app that might come useful.
