Hello everybody,
a few days back I've finally upgraded to Lollipop. All is fine and dandy except for two things.
1. Still stuck with 4x4 grid. After I've seen that the S6 had been given the option to customise the home screen I assumed that with lollipop the bigger screen of the Note 4 will get the same upgrade. Imagine my disappointment
2. I'm using the Samsung keyboard. Whenever filling out forms or logging to any website, switching between input fields makes the keyboard dissappear. Example: tap field 1 and type the login. Tap field 2 to input password, the keyboard dissappears and I have to tap field 2 again to make it reappear.
I've tried the Google keyboard and this inconvenience doesn't occur. Is that a common thing or just my device?
There's nothing I can do about problem number 1 except for other launchers, but maybe someone does know a solution to problem number 2?
Thank you
Thank you
