I AM NOT RESPONSIBLE FOR WHAT YOU DO TO YOUR PHONE! that being said I am not to thank for any of these files I just gathered them up for ya.
first step: downloads
Odin-
Odin3 v1.83.exe
cwm4-
http://attachments.xda-developers.com/attachment.php?attachmentid=657960&d=1310959789
us cellular USB drivers for mesmerize-
http://ars.samsung.com/customer/usa...G_ID=0&AT_ID=343427&PROD_SUB_ID=0&PROD_ID=690
1) on your phone go to- settings/applications/development/ enable USB debugging
2)OK now install Odin on your computer.
3)install USB drivers for mesmerize
4)open Odin
5) hit the PDA button and search for your cwm4 fixed for cm7 file. DO NOT USE THE PHONE BUTTON IN ODIN!!!
6) make sure that repartition IS NOT checked!
7) shut down your phone and pull the battery and the SD card (I never pull the sd card but your supposed to) out.
8)plug the USB cable that came with your phone into your computer.
9)plug the USB cable into your phone and hold down the volume down button until the yellow download screen appears. (about 5-10 seconds).
10) in the upper left side of the screen in Odin there should appear a yellow block that says [com2] (or com 4 or 5 etc. this means that Odin sees your phone.
11) now that everything is ready its time to hit the start button. Odin will show you the progress as you go. after a minute Odin will say RESET, just leave your phone alone until Odin says PASS.
12) OK Odin "passed", now put your SD card and battery back in your phone and do 3button boot into recovery. (hold volume up and down and power all simultaneously until the SAMSUNG splash screen appears then release.
you now have cwm4 and are 1 step closer to root and custom rooms. do this then check back into the forum and we will help with the rest
in case of emergency-
http://rootzwiki.com/topic/3395-samsung-mesmerize-uscc-official-gingerbread-stock-rom-eh09/
1) open Odin
2)check repartition
3) PDA button, locate the stock gingerbread file, select it.
4)PIT button, locate the stock PIT file, select it.
5)shut down phone, remove battery and SD card
6)plug USB into the phone and hold down volume down until yellow download screen appears.
7)check that Odin sees your phone and hit the start button and don't touch the phone till Odin says PASS!!!
you are now back to stock just as it was when you bought it!
