Help Samsung Note 4 stuck on TWRP boot loop
  • Start date Start date
A
Android Question
Guest
I had already rooted my phone and had CMRemix ROM installed. Everything was working fine but I had to factory reset my phone for a reason. And instead of doing it through TWRP, I simply did it through the settings inside the phone. Now my phone is stuck in a TWRP boot loop. Instead of going onto the screen where I can backup, wipe, factory reset, etc, I just get stuck in the TEAMWIN boot screen. It would show that screen, turn off for a few seconds, then reappear over and over again.
I know I should've factory reset through TWRP rather than through the custom ROM's setting...that was clumsy on my part.
I've tried a few different tactics already with downloading the stock firmware and using Odin3 to download that firmware onto the phone. When I tried that, it fails with the phone saying:
SW RE CHECK FAIL: [aboot]Fused 2 > Binary 1
[1] eMMC write fail: ABOOT
Is there anything else I can do to have my phone working again? It can either be back to the original firmware or CMRemix ROM. Thanks in advance!
What model Note 4 do you have?
Did you try the most current firmware when you tried flashing stock?
Have you tried to flash TWRP again?
Did you make any backups with TWRP before this happened?
