Help Samsung Note 5: Wireless Charging Internal?
PeteCress
I keep seeing references to "Wireless Charging" with the Note 5 - and I see aftermarket kits that make me think that maybe it's an add-on.
If it is an add-on, does the receiver part fit inside the case, or does it ride outside the case?
If it comes built-in, is a $30.00 charging pad all I need ?
e.g. http://www.walmart.com/ip/Samsung-W...5409688&wl4=&wl5=pla&wl6=107410634928&veh=sem
How about the el-cheapo ones for $10.00 ?
e.g. http://www.amazon.com/Wireless-Char...5&sr=8-12&keywords=galaxy+s5+wireless+charger
It's not an add-on,it's built-in to the phone.
As for wireless chargers,I'd get one of the newer fast charge pads from Samsung OR a brand that specifically states that it is fast charge.
Neither one of the ones you listed are fast charge enabled
If it were me,I'd invest a few more $'s for the fast charge variety.................
