They Did but it wasn't for 2.1
Using tapatalk![]()
At least you'd have a point of reference ;->1) No, Samsung does NOT need to release driver sources under the Apache Liscense (I was also under the impression it was GPL, but in any case, even under GPL, they would not have to release proprietary hardware drivers)
2) The Galaxy S is not the same as the Galaxy (which is essentially a slightly different Behold II). It's different hardware, so the drivers wouldn't work
3) Technically, even having 1.5 driver sources would work for 2.1: You'd have to re-create the sources to compile against 2.1 using the 1.5 sources as a base. Not sure how easy this would be, but it'd be a DAMN sight easier than trying to build them from nothingAt least you'd have a point of reference ;->
yeah, because online petitions always produce results.
You clearly have had little to no experience with this situation or dealing with samsung! They will not release driver source code, period! It is their propritary software for this phone and not open source! Behold 2 source code has been requested in writting many times and samsung has responded in writting many times saying they have all ready released all code required by google and apache lic. They have stated that these sources contain code sections that are related to other samsung products and will not be released to maintain the security of the behold as well as many other samsung products effected by it.
i have seen it and has nothing to do with what i said! galaxys is s-amoled not amoled totally different drivers totally unrelated to samsung led and 3d tvs which are amoled. now pay attention here: the behold2 uses the same rsf security as their tvs, while the galaxy s does not. thanx for chiming in though.
He also stated in that very thread that it will NEVER be stable enough for an "everyday driver" rom that's why he never released it. But you can download the original work in progress file and go to work yourself but I will warn you several have tired and all have failed!
So much misinformation here. That's gotta be one big reason he and many many more have left this forum! Enjoy eternally waiting for your 2.1 enabled b2! Get a commfy chair and a good mag for your wait
BH_MAN said:Well the biggest thing is the Sound.. If sound worked 2.1 in my testing would be ready for everyday use... As BT / WiFI / Data / Signal / Video all worked on my Test Rom's... If we could get Sound working we would be golden..paul89 said:Do you still think there might be hope for 2.x on the BH2? If not I'm looking around for a different Android phone soon!
That was the Only thing stopping me from release a 2.1 rom![]()
