bigkountry3946
Hi all.
I have a Samsung Rugby Smart SGH-I847 with root and my reason for rooting my device was because 1) AT&T has alot of bloatware/stock apps installed by default that I will never use. 2) After downloading apps & games most of them were lagging so I thought if I could uninstall the stock apps that I wont use it will free up enough memory to make other apps run smoother without lag... I was wrong. Even after uninstalling the stock apps and overclocking my device the apps still lag and I am tired of it...
I've been reading & researching for the past 4 months and trying to understand all of the technical terms involved with android devices but some of it I still don't understand but am very eager to learn.
Clockwork recovery: What is compatible for my device? How do I find it to download and install?
ROM: Is this referring to gingerbread, ICS, and Jelly Bean? Where can I find the best for my device and how to download and install? What is compatible for my device? Will flashing a newer rom speed up my device? Increase memory?
Kernel: I read that it is like a translator between the OS and software. Is this correct? How to find download and install? Will a newer kernel version speed up my device?
Is there anyway to increase the RAM? If so, how to? Will this speed up my device?
I know these are alot of questions for one thread but all in all what can I do to squeeze every bit of potential out of my I847 and prevent it from lagging?
